I’ve never experienced this issue before but today the outline I normally have around gemstones has stopped working. I tried using an ellipse which works well in grasshopper but seems to have the same issue as the internalised curve in ShapeDiver. Also the box to enable global domains for a model when uploading it seems to have stopped working maybe its related. What have I done wrong?
It is likely that you need to convert the curve to a polyline, otherwise our viewer will do it automatically and sometimes produce non-satisfactory results. Try to convert the curve to a polyline in Grasshopper and check the results.
About the global domains checkbox, the UI has changed recently to fix an issue but it should work. Let me know if you have trouble embedding the domain when you enable the checkbox.
