There is no curve internalized in your curve input, which explains why for default parameters you do not see anything in the viewer. Your goal seems to connect to a desktop client, in which case you will be able to select a curve from Rhino or Illustrator for example. If you want to show something for default parameters, make sure to internalize the curve you are referencing from your rhino document.
