Dear @dale
Dear Everybody
Rhinocommon can not close this attached Curve:
makeClosed_test_or_bug.3dm (32.8 KB)
Something is wrong with the complex Curve (green at the right) in the attached Document. The curve is the former Brep-Face-Outer-Loop of a solid, the solid is designed in Solidworks and imported as sldprt.
Rhinocommon s Curve.MakeClose returns true on this curve, but the Curve is not closed afterwards.
Curve.IsClosed; // false
Curve.MakeClose(0.001); // returns true
Curve.IsClosed; // still false
i used the attached command to test.
works fine on the left open rectangle-shape.
what is wrong ?
Thanks for your Help.
best Tom
const ObjectType filter = Rhino.DocObjects.ObjectType.Curve;
Rhino.DocObjects.ObjRef objref;
Rhino.Commands.Result rc = Rhino.Input.RhinoGet.GetOneObject("Select curve to close", false, filter, out objref);
if (rc != Rhino.Commands.Result.Success || objref == null)
return rc;
Rhino.Geometry.Curve crv = objref.Curve();
if (crv == null || crv.IsShort(Rhino.RhinoMath.ZeroTolerance))
RhinoApp.WriteLine("Curve is short");
return Rhino.Commands.Result.Failure;
if (crv.IsClosed)
RhinoApp.WriteLine("Curve already closed");
return Rhino.Commands.Result.Success;
if (crv.MakeClosed(doc.ModelAbsoluteTolerance))
RhinoApp.WriteLine("MakeClose reports true");
string message = crv.IsClosed?"closed":"still open";
RhinoApp.WriteLine("Now the Curve is " + message);
doc.Objects.AddCurve(
crv,
new ObjectAttributes()
Name = "ShoulBeClosedCrv",
ColorSource = ObjectColorSource.ColorFromObject,
ObjectColor = System.Drawing.Color.Red
