Using Grasshopper to Curve Boolean all open curve regions?
I am wondering if there is a quick way to Curveboolean all the regions of all intersecting open curves ?
I have tried to use Geometric Regions from Heterptea but failed from time to time when there are too many close interactions. Do I need to use Rhino. command to archive the desired result? Thank you
Depending on your curves, this might be possible by creating a planar surface through a group of coplanar curves and splitting this surface with the curves.
If you need more help, post a Rhino file with the relevant curves.
Hi Martin, thanks for the reply. Here are the curves I am working with. For some reason, I was able to curve boolean all within Rhino, but couldn’t achieve the same result by using the Heteroptera’s Geometric Region func
Curves.3dm (144.6 KB)
tion.
Hope this helps.
curves_surfaces.gh (15.1 KB)
Thank you Martin, I will have a look of your script
