Description:
The cursor won’t jump from the key field to the value field by pressing ‘Tab’ when creating a new entry.
Steps to reproduce:
- select an object
- go to ‘Attribute User Text’ panel
- insert a new User Text ([+] icon)
- type the key field
- press ‘Tab’ >> the cursor won’t move to the ‘value’ field. You have to manually click on the value field.
Expected result:
The cursor should move to the value field right after pressing ‘Tab’ for easy typing.
It seems to work great when the user text already exists:
- double-click on the key field + edit it
- press ‘Tab’
- the value field get highlighted and is directly modifiable.
Thanks in advance
