Button Editor Tab key regression
Hi there,
in R8, the Button Editor has a slight issue using the Tab key to cycle from field to field. In below video, i’m starting by clicking in the Text field and then pressing Tab to go to the next field or TabShift to go to the previous field.
ButtonEditorTabOrder
It seems that the cursor is cycling through the Command field content and not over it which causes that the content gets changed. Please try R7 for comparison / the expected behavior.
thanks,
c.
Hi Clement, thanks I’ll check it.
RH-80294 Toolbar: Tab key to change fields is incorrect
