I am learning the capabilities of culling data in grasshopper. I am struggling culling the item highlighted in the image. I am wondering if there is a way to cull the surfaces that are higher than a certain z axis. Or if there is a better way to select these surfaces as I cannot select them with a list item and a series. Attached is the image of my script and rhino viewport.
Thanks so much in advance for the help.
There is probably a way to do this by culling but I saw it as a tree management exercise. That turned into a complex monster, sorry! The splitting is done at the yellow group. All the rest (which is most of the code!!) is about presenting the results sorted by Z, in two “groups” corresponding to the two surfaces. The purple group in particular is weird. Its purpose is to partition the list of paths from TStat(Tree Statistics) so they can be sorted by Z. Again, sorry
P.S. I just noticed that each branch is not sorted by Y.
P.P.S. While adding sort by Y(gray group), I noticed small sections along the left edge because no contour start point was used. So I added the orange group for that.
