I changed the path of the HDRI env to a new directory, but if I start an animation rendering, than I get the message, that the texture is missing. But if I skip the error message than the rendering works fine. But at the next frame the same again.
Ciao, Micha
Sorry - I missed this post Micha. Is this still an issue? It looks like the r:\Temp\HDRI.hdr file doesn’t exist.
Paul
Right, the file from the temp dir was deleted and a new path was set.
Tested with the last build today - no problem anymore.
Thank you, Micha
