Hello every one, i have made too many trials but i could not create a surface like in the picture from those 3 curves. Is there any ideas for me to create that curve. Thank you very much!
Hi pascal, firstly thank you for your respond, but this surface is not the same with the one o try to create. In this surface it is going upwards at the approximate middle but i try to create like in the pic i have upload, which goes directly downward from the front curve.
It seems it worked. Thank you very much!
Even though you’ve got what you want you might find a forum search for “soap film surface” quite interesting.
I will check it out. Thank you!
