Trouble in making surface from 3D curve
Hi, I am making a watch strap, I made a top and side view of curves, than create a 3D curve with Crv2View, but how to make surfaces from the 3D curve?
20220124.3dm (40.4 KB)
I tried to split the 3D curves and make surface with EdgeSrf. I am not sure this is the desire way because I don’t know how to reduce the control points of the curves.
20220124.3dm (193.8 KB)
Hi @hungwai.lim,
A simpler way to do this would be to delete the black curve and rearrange the blue curves like this:
Then extrude the vertical section wider than the horizontal curve, using the BothSides and Solid options:
And use Wirecut in the top view, with the horizontal curve as the cutting curve, to split the extrusion:
Before deleting the unwanted part:
HTH
Jeremy
Hi jeremy5,
I got it. Thank you very much.
