Currently I create path and topo from mesh using lands design on rhino-inside-revit. So, when I’ve done with the path obviously it categories as topo also. The question is, how can I turn the path in topo category to be defined as floor by using lands design? I wanna thanks first before your respond!
Hello @Yoshua_Glibert,
In the files uploaded to Food4Rhino path objects are already defined in Revit in the Floor category. Anyway, if you open the Grasshopper definition “03-PATHS”, you can change the Revit category in the following component:
Just choose the one you prefer and all the path objects will be defined in that category.
In case you are using the _laTerrainAddPath command instead of creating a path object, please, take into account that this command is used to modify the terrain but the geometry will remain as a terrain, it will not be converted into a path.
