the grasshopper window is permanent it closes with each action outside of revival it is very disturbing
*when creating the family it would be interesting to be able to make a subcategory by geometry inside family
*I have the impression that the topographic elements(direct shape with topography catégory) are inert and cannot work with revitalised on these objects
A very good plugin with great potential,
I’ll continue my tests and probably come back here!
I have the same opinion about that. Rhino/Grasshopper shouldnt close just because I am checking something in Revit or in any other Program.
Its disturbing that I have to open it every time again. Is there a possibility to change that?
The Grasshopper and Rhino window thing is something we know should be changed.
When creating a family you can assign subcategories to the geometry using the FamilyElement.ByBrep. This definition may be used to define a Railing family.
Instead of adding a DirectShape in the Topography category, please use the Topography.ByPoints it will create a system TopographySurface in the Revit model.
