Creating layouts with named views with section cuts and section styles
Hello. I think Drafthorse is brilliant and has huge potential. I cut various clipping sections through a film set model and at the same time create named views from these. When I make details in Drafthorse it shows the correct view but the view doesn’t cut through at the clipping section plane. That means if there are objects in front of the clipping section, those objects are also shown in the view. When I add a detail manually in Rhino and then bring in a named view it shows the view correctly with the section style applied. Am I missing something?
@jokamm Should be able to help you
Thank you very much. I sent him a message.
