Is there a way to create custom chamfered wall in Revit using Rhino.Inside? The cut is a custom shape like I am showing on the right side in the image. Right side in the image is Rhino space and left side is the Revit space. I have all the geometries required to create the solid difference, but not sure if there is any component that can extrude a void in Revit and host in on the wall to somehow cut the wall.
>> Creating Direct Shape from grasshopper to Revit is not an option and it has to be a Revit wall.
