hi,
I used Brep.CreateContourCurves() but there are more contours created than the number of section planes. The input planes are 78 and output curves are 91.
extra curves between plane
Hi @neerajsmurali
I’m assuming you are using grasshopper or code for that?
Are you able to provide a model and script?
I am using the C# component in grasshopper but the grasshopper component Brep|plane is also giving the same result…
00.3dm (893.2 KB) 00.gh (22.7 KB) GrpcLatLon.gha (10 KB) gpx.rar (20.7 KB)
Planes are infinite:
CreateContourCurves is close enough to your plane origin:
foreach(var plane in planes)
var contCurve = Brep.CreateContourCurves(loftedSurface[0], plane);
foreach(var c in contCurve)
var t = 0.0;
if (c.ClosestPoint(plane.Origin, out t, 10.0))
contourCurves.Add(c);
alternatively, if you don’t have the scale in the outer foreach loop (also null checks might save you time debugging)
IEnumerable<Curve> fromBrep = Brep.CreateContourCurves(loftedSurface[0], plane);
Curve result;
if(fromBrep!=null){
IEnumerable<Curve> filtered = fromBrep.OrderBy(x=>plane.Origin.DistanceTo(x.PointAtNormalizedLength(0.5)))
if(filtered!=null){
result=filtered.First();
Thank You @Mahdiyar
Thank You @Thierry_BOCK
