Hello, I’m trying to retrieve contour curves between a polysurface and a plane.
The method Brep.CreateContourCurves works fine but I’d like to get the curves per every surface in the polysurface.
Sorry, english isn’t my main language, I prepared some screens to better show the situation:
If I intersect the polysurface and the plane I get one single curve
But my original polysurface is made of three surfaces. Would it be possible to get the curves for each surface even if they are joined in a single polysurface?
I think I can probably access underlying surfaces using Brep.Surfaces and then make it work from there by first testing bounding boxes for intersection then getting the curves but I just want to be sure I’m not reinventing the wheel.
Thanks in advance!
