Lofting Curves from Brep to Create one Surface
I am attempting to turn my Brep into one surface so that I may panel it easily. I contoured the Brep and found an instance within the curve list where it would be trouble, so I culled that, and tried lofting the remaining index. However, nothing is being created.
I thought that it might be the number of control points on each curve, but when I try to analyze that it states “Data failed from integer to curve”.
Is anyone able to let me know what is going wrong?
Thanks in advance
Lofting For Help.gh (151.0 KB)
UPDATE,
I managed to get the loft component not to go red by setting a start point and by lowering the number of contours. However, the loft does not show anything. Also, the list length of the contours and the loft is 112, when I clearly do not have that many so something is happening organization of the information. However, I cannot figure out what. I have tried flattening them but it does not work.
Thanks in advance
Update.gh (153.9 KB)
Hi Brenden,
Unfortunately I get a bad loft:
You need a single point which I just used the bounding box and got the bottom most corner.
The loft is then flattened, however you will need to work through the loft options for a good loft.Update.gh (156.2 KB)
Thanks for the response!
I was unable to do this through the method shown. I think the geometry has multiple parts that split off and have very different outlines/lengths etc. I simplified the geometry and now it works fine for the purpose that I need it for.
Cheers
