Hi all,
I am new to programming and I have recently discovered Grasshopper. I am building a parametric design for my graduation project. The grasshopper model is used as input for an FEM program called SCIA Engineer, which has it’s own plug-ins called Koala.
I need two 2D-members, which can be defined by a module in Koala. I have added a file which shows a couple of surfaces, points and an opening. For my project I need circular 2D members. In the file I have grouped two blocks of modules in the top.
The Srf4Pt creates a surface, which is plugged into the 2D member module. You can see it creates output. The cluster above shows my circle, but when that is plugged in the 2D member, it does not work. I’m wondering why this doesn’t work.
Does anyone have a clue how to get the cicular surface in the 2D member module?
Thanks a lot,
Ruben2DMemberWithOpening.gh (19.3 KB)
