Is it to do with the evaluate surface and circle functions right at the beginning? I can get the script to create the points but it will not do so according to the example image where its a rectangle with a conic hole.
Please help I have tried everything I know how, would be much appreciated if anyone could help fix my script!! (attached below)
I dont have all the plugins you are using, but it looks like you didn’t reparameterize the surface on the input to the Evalute Surface component. Right click on the S input, and select reparameterize.
By the way, when you are sharing a GH file, be sure to internalise any data you reference from Rhino. If you are not sure how, see the link below.
