I am working on adaptive circular panels, that I have created in Grasshopper. I have tried to implement it into other surface, since i need more rounded shape. Is it possible to do it somehow?
I am lost in how to achieve it and I will appreciate help, since Im new to Grasshopper.
There are several things going on in this model. When you say “i need more rounded shape”, do you mean instead of the rectangular array of points?
Why is Distance is measured from two different points? And what determines their locations? I would think the average point would suffice for both?
Oh, damn! I just realized you have two copies of code in this GH file amd I was looking at the hidden one (“OTEHER DESIGN OPTION”[sic]). Waste of time… I won’t bother with “THIS ONE!”.
Dispatch before Circle makes no sense, there are earlier controls to get the same thing.
A domain applied to Circle ‘R’ (radius) makes no sense.
WOW, that is amazing, thanks anywas for help.
My point is, what if I want to implement those circles in surface I made in Rhino that is more rounded, but not actual circle. Like how to adapt it to the lets say brep im making?
OK, well, that’s a different approach entirely. I’ll need to have that surface if you want me to try? If you want to try it yourself, just connect this new surface directly to SDivide.
Meanwhile, there are many things that can be done… Without knowing what you want, I added a Graph Mapper to smooth the effect (white group). Still using one reference point for both position and rotation. Not sure that works with this new surface (that you must post!).
facade_for_gsh.3dm (94.3 KB)
There are two surfaces I wanto apply this pattern. I will appreciate help with one of those, the other one hopefully I will do myself if I will know how to approach it !
These surfaces (internalized, so no need for Rhino file) are at a vastly different scale than the rectangle and circle in version ‘28b’ above, so slider values must be adjusted accordingly.
I had to flip both of these surfaces so their “normals” pointed “outward”.
I used SFrames instead of SDivide. Using Average for the “attractor” reference point might no longer be ideal…?
Because of their curvature and how they were created, isocurves and the surface frames I’m using are bunched up in some areas, which might not be ideal…? Another way to get these surface frames would be to divide their top and bottom edge curves to get lines between them that are spaced more evenly?
The position (Move) and rotation domains, circle radius and U/V slider values need to be adjusted for these surfaces. I changed them a little but their values are up to you.
Hi, I wanted to ask you, how I can add different surface to value list? Now my shape changed totally into lets call it " tube" which is more simple, but when I try to change it there are some errors coming, Im not sure how to do that. I would appreciate advice
I don’t understand what for such tone.
I can understand that my question might sounds for you silly, cause you have more experience and knowledge in software, but if you don’t understand what I’m asking for maybe clarify it instead of being inpolite?
I’m simply asking how to use value list, how you can change or add surface to it, I don’t see the point of giving you the file, cause you simply have it in comments above added by you…
I would like to understand how to do it rather than looking at script.
That is the reason people sometimes are afraid to ask questions to not be gaslighted by people like you.
