I am trying to create a set of surfaces from points which I extracted from a set of lines. all the points read as 0. I have a attached both my script and a quick screen grab of what I am trying to do. I need each of the groups of three to create a small triangle. from this I can then find the centre of each one to create an end line of my surface. any advice would be appreciated!
Attached another approach, starting with the original lines endpoints, so you have a structured datatree from the start.STRUCTURE FOR MODEL_SG.gh (83.4 KB)
also noticed one of your curves has flipped offset…
