Hi Everyone,
I’m doing some Grasshopper exercises trying to learn more how to work with data trees and lists. I have a (hopefully) simple question. I’m trying to create a surface from a set of points. I split the set of points into 2 data sets so I can have separate control over the last 2 rows of points. When I try to merge these points back together and use the “Surface from points” component the surface looks pretty weird, I’m assuming it’s because of how the data is being read.
Here is an example of what I am more or less trying to achieve (how it looks when I don’t try to separate the data)
Here is a snip of the section of my code dealing with this area
Here is the result I am currently getting
The patch command kind of works? But it offsets the overall size which I do not want. I plan on lofting it to the original curve with the new surface. Also - I would like to learn how to figure out a problem like this while still using the “Surface from points” component
Any help is appreciated!
Surface From Points.gh (12.5 KB)
