Hi! I would like to make a solid out of two different parallel surfaces/curves.
Is there a function to make it happen? I am fairly new to rhino so still learning many commands.
Hi @dkim
Take a look at the commands loft
and sweep2
in the help file - that should get you started. For both commands you can use the surface edges of your existing surfaces as input curves.
HTH, Jakob
Sweep2 did the job thank you so much!!!
