Creating a custom material library in Mac Rhino
Is there a tutorial on how to create a custom material library in Rhino Mac? Have been able to modify a metal to what I want but cannot figure out how to make it available to all new files.
Been searching the forums and not found anything. I have lost the use of my materials plugins in the move from Rhino Windows to Mac.
regards,
Sochin
Hi Sochin - in the Materials panel, select the material, right click, and choose Save to file.
Import that rmtl file and any others you would like, into aother file from the same menu
  • save that file Rhino file as a template and use it to start new models.
You can also save that rmtl file to a folder, add the folder to the Libraries panel and get to it from there in any file.
Images are Windows but mac is about the same.
Thanks @pascal as always :slight_smile: I am hoping your scripts work on the Mac …especially Distribute.
cheers,
Sochin
Hi Sochin - Distribute is a native command in Rhino 7.
@pascal excellent.
