I have a file which contains a handfull of points and their respectful text height. I have thousands of these. The following example is a small sample:
At the moment i can only click on individual points and move them to their Z coordinates according to the text. And once i do this for every point, patch to create a terrain.
Is there a way to automate this tediouse workflow with grasshopper?
I tried using this at a different section in my model and I am having some slight issues where the amount the point is moved in the Z direcction does not always match with its closest text value. Not sure what i am doing wrong…
[I didn’t have the very same versione of Elefront installed, so you might see a white component… just connect the Attributes output of one of the two components to the A input of the bake ]
