Diana_Fox
(Diana Fox)
April 25, 2024, 5:39pm
1
Survey.3dm (14.9 MB)
I have this fine which contains a lot of points with text next to the point which indicates it’s elevation in the Z axis, how could I move each point using grasshopper based on the neighbouring next to the point? (for topography from spot elevation)
Many thanks
inno
April 25, 2024, 8:00pm
2
the text tags in the file contain also words, so I thought a good first step might be to filter-out non-numbers
then you can connect each point to the closest residual texts, which should be all numbers, and push the result up by their values
there are some situations you need to be aware of, for instance:
two points connected to the very same number text, because it happens to be the closest to both:
same, but 4 points connected to the very same text-number value:
weird stuff going on next to the island:
weird stuff going on in general
final result:
not very sure what I’m looking at not an architect
this is the definition, maybe it could be the starting point for something more elaborated:
Survey.gh (13.0 KB)
Diana_Fox
(Diana Fox)
April 26, 2024, 2:48pm
3
Thank you so much for this, it’s exactly what I wanted!
