Hi there, we are regularly working with topographical surveys with spot heights taken at multiple locations on the site.
We are looking for a Rhino 5.0 script which allows you to select the texts and then creates points a certain distance away above the text based on what the text reads. For example, if the text shows 43.21, the script should create a point exactly 43.21 units away on the Z axis.
Spot Heights.3dm (875.0 KB)
Thank you for the quick reply! I had a look at the topic, but I don’t think this is what we had in mind.
Sorry, I didn’t make that clear. The text is already imported from .dwg in Rhino as separate text points in the correct location.
Just need to select all of them and create a point for their height based on what they read.
I have attached the .3dm, if that helps at all.
Your file is in mm, but I believe the heights should be in m (according to the content)… So maybe first change the units in the file to meters and accept the scale prompt (will not affect the texts themselves, just the xy location scale)
Also, the script above will not parse anything that is not a pure number, so the entries like
Ridge:63.91
will not get a height point. I would need to do some fancy checking (maybe with regex, ugh) to extract any numbers contained with letters in alphanumeric text strings.
Looks like @Helvetosaur beat me to it but here is another solution with simple number extraction and scale option:
import scriptcontext as sc
import Rhino
numbers = ['0', '1', '2', '3', '4', '5', '6', '7', '8', '9', '0', '.']
def parse_text(text):
# probably not performant but simple
new_string = ''
for char in text:
if char in numbers:
new_string += char
return float(new_string)
def parse_text_objs():
# unit stuff
units = {'mm': Rhino.UnitSystem.Millimeters,
'm': Rhino.UnitSystem.Meters,
'inch': Rhino.UnitSystem.Inches,
'feet': Rhino.UnitSystem.Feet,
doc_units = sc.doc.ModelUnitSystem
unit = rs.GetString('select dimension units', 'm', units.keys())
dim_units = units.get(unit, None)
if dim_units is None:
print 'unsupported units, using mm'
dim_units = units['mm']
factor = Rhino.RhinoMath.UnitScale(dim_units, doc_units)
# object selection
guids = rs.GetObjects('select text objects')
# turn off redraw for faster loop
sc.doc.Views.RedrawEnabled = False
for guid in guids:
geo = rs.coercegeometry(guid)
if type(geo) == Rhino.Geometry.TextEntity:
# use the text entity plane origin as base point
plane = geo.Plane
# parse out the numbers in the text
height = parse_text(geo.Text)
# make a new point at plane origin with new z scaled
point = Rhino.Geometry.Point3d(plane.OriginX, plane.OriginY, height*factor)
# add point to the doc
sc.doc.Objects.AddPoint(point)
sc.doc.Views.RedrawEnabled = True
parse_text_objs()
Output for mm and m scale (2 runs) on the example file:
