Create Surface from Non Planar Curve
Hello Rhino forum,
I’m a newbie working my way through the Rhino Level 1 Training Guide.
I want to create a surface from a non-planar curve as shown below, with no curve in the x direction. Which commond do I have to use? I tried “Patch” but that creates a surface with a bend in the x direction.
Perhaps someone will take the time to answer my very basic question, thanks!
please upload your curve here.
Bar.3dm (2.8 MB)
Hi Alex, It is basically a cylinder. The radius is around 6.25. You could extrude a cylinder then use the curves you have to split that cylinder. That is one way to get there. —Mark
i simplified the curve before splitting but it should work without either.
Bar.3dm (6.6 MB)
I used @encephalon’s suggestion, which seemed the most straight forward to me.
I will also try to build the surface using @11165 and @markintheozarks suggestion, seems I can learn something here.
Thanks, guys!
I strongly recommend using extrusion+split on developable surface like this.
