I know that the components available at the time of writing this do not allow me to apply Rhino’s slanted surfaces directly to the Add Wall(Profile) Component.
If I enter it, a vertical wall will be created instead in Revit.
We can edit the slanted wall in Revit using parameters, but I would like to create it by inputting the slanted surface as is for a more intuitive modeling experience.
My idea is as attached. If you have a better idea, I would like to hear your opinion.
And I would prefer if one day the Add Wall(Profile) Component could create the slanted wall directly.
I have a program for a sloped floor as well, but that one is a bit more complicated, so I will discuss that another time.
The following has been added:
It appears that when the level is changed, an error occurs due to the processing order. To avoid this, Data Dam must be added before Add Wall(Profile) Component.
This is to shift the timing of the processing of Element Parameter.
