Hey, maybe this is more complicated then it looks: I have a bunch of 2d curves and I´m trying to generate the surface “in between”. Some curves intersect others, some do not. What I tried so far:
Shatter the curves on the intersection points. Doesnt work for all curves because some have no intersections. It´s also hard to shatter/remove the correct curve segments because how do I filter for the correct ones (blue or green?)
Extending the curves first to generate intersection points. Then use Surface-Split component. With a concave shape this generates a lot of intersections that do not represent the correct corner points of the disired shape. The inner region will be cut into many different pieces.
Using the “Region” component of the Fennec Plugin: Doesnt work because all lines have to intersect. By extending all lines first the surface (again) will be cut into several different pieces.
I guess it has to be kind of a two step process where I first somehow connect the intersecting curves, then extend those ones with all the others. Can´t make it work ![]()
Please help! Thanks in advance!
Related but not working for me:
question2.gh (1.1 KB)
question.3dm (171.8 KB)
