Hi
I’m trying to create a 3d view but I can’t get the orientation correct. What does the ‘plane’ refer to?
If I look at what the API is after so that I can construct the necessary GH plane:
Thanks
Looks like it refers to the Level Picker
The input ‘Plane’ is the plane where all geometry will be projected.
UpDirection is codirectional with the Y direction on the input ‘Plane’. It use to be Z Axis. On those screenshots is represented by the green Y axis on the plane.
UpDirection
If you rotate that plane 45º you have this
If you like to construct the plane from ForwardDirection.
ForwardDirection
An other way to construct that plane may be ‘Rectangle 3Pt’.
