Hi guys.
I learned the basic stuff about: Grasshopper, Revit, Rhino.Inside.Revit, Rhino, General Python, GHPython and IronPython and completed some courses from McNeel education. I am working in Revit 2023 and Rhino 8 (WIP).
I jumped straight into GHpython scripting trying to create a pipe in revit from two points created in rhino and couldn’t find any good examples to learn from (plumbing/ MEP examples) so I am stuck. The examples are only written in C#, Visal Basic or Visual C++. I have just started with python coding and there is so much information to handle and read and that makes it hard when I am not knowing where to start. There are so many libraries to import and all of these confuses me what they really do and I really struggling to get all the pieces together where they belong.
What I have done by now:
I’ve downloaded and installed Revit 2023.
I’ve downloaded and installed Rhino.Inside.Revit
I’ve downloaded and installed Revit LookUp.
I’ve downloaded and installed Rhino 8 (WIP)
I’ve understand I need a transaction, think I know how to do this.
I’ve been searching around in revitapidocs.com and found this class I want to use (Creates a new pipe from two points):
https://www.revitapidocs.com/2023/9550265f-5760-3c28-d023-d0373285855b.htm
I’ve tried to translate the information found in revitapidocs.com to GHPython in several ways, but can’t get it to work with GHPython.
Anyone out there who can give me and example written in GHpython that works and explain with easy comments what to do for the create pipe class and get the pipe drawed inside revit?
I really want to learn this but I need some guidance in the start where to look and where to start, please keep it as simple as you can get it. I need a basic easy explained recipe for the whole process.
When I’ve learned the basics the plan is to expand the code from there.
I really appreciate all the help I can get here.
