I try to create multiple oriented planes on a curve through the shape of the mesh, the orientation of the planes depends on the shape of the mesh (Z is parallel to the mesh surface), I tried curve frames and perp frames, the planes created are very difficult achieves what I need. Need your help, thanks in advance.
I think I didn’t explain clearly enough. I want to create these planes in the picture on all the curves. Thousands of planes surround the entire mesh. The Z axis of the plane is parallel to the surface of the mesh. Thank you
