Vertical Linear Grid on Surface.gh (6.5 KB)
I am trying to get the grid on the surface to be vertical. And not go along the geometry of the surface. Attached are some screenshots of contours, showing the direction that I would like the grid lines to be in.
Any Help will be highly appreciated!!
Thank you!!
Hello!
Thank you!!
Attached is the further version of what I would like to do with the vertical divisions. I would like each of the panels to rotate on its own axis / mid point as shown in the screenshot.
And the Script attached.Variable Panelling_Vertical Grid.gh (11.3 KB)
Thank you in advance.
Use rotate component. For center of rotation put the center points. Just read a bit the input description of components.
Hi Michael,
The Grid on the above image needs to change to a Vertical Grid and then allow for rotation. As mentioned on the earlier post. Attached are images again.
Thank you.
Contour, Split surface, Get centers of splits, rotate. Give it a try and post your efforts.
Hi Michael,
Thank you for the guides. It worked perfectly!
Attached is the screenshot.
Thank you!
