I’m trying to create a filled region using the workflow as described in the online guides but it doesnt seem to work. I dont get an error message either. Does anyone know why?
Many thanks,
Stephan
Many thanks,
Stephan
There’s an error in the create filled region code.
line 29:
revit_curves = [Convert.ToHost(x) for x in C]
Should be
revit_curves = [Convert.Geometry.GeometryEncoder.ToCurve(x) for x in C]
Hi Japhy,
Thank you for your answer.
How and where can I change this?
Many thanks,
Stephan
Double click on the component icon (pink)
Brilliant. Thank you!
@Japhy , I am trying to create a custom pattern as a Filled Region. unfortunately the node " Find Filled Region Type" does not work.
Hi Pixypk,
You can find the Filled Regions Types via Query Types.
Narrow down your list by filtering by Detail items category.
Hi Japhy, I have another question, is it possible to align a Material_ model hatch pattern for a selected element via GH?
Not impossible with some scripting. See post 15 on this thread for a rough idea.
Can you tell me a little more about the workflow? Type of Element(s) and methodology of alignment?
I’ll add Align to Reference as a feature request.
@Japhy, sure. I am working on an office building that has different types of rooms with different ceiling materials. I have sorted the office rooms by ceiling material and created different tile options for the suspended ceilings. In my first attempt I brought the pattern as detail lines which made the Revit model very heavy.
Now I want to see if it is possible to create a pattern on the ceiling material and align each room’s pattern to the pattern I have for it in GH. Doing this for each room for 15 floors by hand in Revit is not fun …
