Create & distribute command?
does Rhino have a command that both creates and distributes lines perpendicular to a reference line? I found the “distribute” command but it appears to only distribute existing objects… image a grating.
Art
Could you give it a try with the ArrayCrv ?
Jessesn-
thanks for the suggestion! tried “ArrayCrv” with the “Help page” open and can’t get past selection of the curve to array and selection of the curve to distribute along. those two choices made, the command opens a massive dialog box that I can’t make heads or tails of even with the “Help page” open… there’s options for everything under the sun; a very simple example would be greatly appreciated
Art
I made a video earlier — is this the result you want? If so, you can refer to it and give it a try.
BTW, the ArrayCrv process is actually quite simple — just three steps:
  1. Select the objects you want to array, e.g. a line segment as in the earlier video.
  2. Select the curve you want to array along, e.g. the long line as in the earlier video.
  3. Set the spacing, size, direction, and alignment mode, etc.
Could you share this 3dm file? and I’d like to know which curve is the reference line in this file?
