kenzan
(Kenzan)
May 5, 2021, 8:17pm
1
I’m trying to make cones with a specific degree spread. is there a way to do this? I also want to be able to extend the cone if it is not long enough.
Alternately, If I could create a spot light that I can do this with, I would be similarly happy.
Thanks!
pascal
(Pascal Golay)
May 5, 2021, 8:32pm
2
Hello - I have a script someplace that will let you set one or more spotlights to a particular angle - would that help?
wouldn’t extrudeCrvTapered help here?
kenzan
(Kenzan)
May 6, 2021, 1:58pm
4
Yes it would. I have not started using scripting in Rhino yet, but I’m interested to try.
kenzan
(Kenzan)
May 6, 2021, 2:02pm
5
DiegoKrause:
extrudeCrvTapered
Its a funny strange work around, but this works! It’s just a visualization, so this is enough accuracy. Thanks!
pascal
(Pascal Golay)
May 6, 2021, 5:24pm
6
Hello - this is an old RhinoScript (Windows only)
Spotlight Angle_EX.rvb (2.6 KB)
To use it, drag and drop it onto an open Rhino window, and then use the command (actually an alias)
SpotlightAngle
