I love how I can run the alias that calls this script and just type in the name…just so long as it is one word.
Is there any way to modify this script so that pressing the tab key when entering a name longer than one word will not finalise the command? BTW thank you to whoever created this script
cheers,
Sochin
import Rhino
import scriptcontext
import System.Guid, System.Drawing.Color
def AddLayer():
# Cook up an unused layer name
unused_name = scriptcontext.doc.Layers.GetUnusedLayerName(False)
# Prompt the user to enter a layer name
gs = Rhino.Input.Custom.GetString()
gs.SetCommandPrompt("Name of layer to add")
gs.SetDefaultString(unused_name)
gs.AcceptNothing(True)
gs.Get()
if gs.CommandResult()!=Rhino.Commands.Result.Success:
return gs.CommandResult()
# Was a layer named entered?
layer_name = gs.StringResult().Trim()
if not layer_name:
print "Layer name cannot be blank."
return Rhino.Commands.Result.Cancel
# Is the layer name valid?
if not Rhino.DocObjects.Layer.IsValidName(layer_name):
print layer_name, "is not a valid layer name."
# Does a layer with the same name already exist?
layer_index = scriptcontext.doc.Layers.Find(layer_name, True)
if layer_index>=0:
print "A layer with the name", layer_name, "already exists."
# Add a new layer to the document
layer_index = scriptcontext.doc.Layers.Add(layer_name, System.Drawing.Color.Black)
if layer_index<0:
print "Unable to add", layer_name, "layer."
return Rhino.Commands.Result.Failure
return Rhino.Commands.Result.Success
if __name__=="__main__":
AddLayer()
