Creating a new layer and renaming automatically using Python script
I was wondering if anybody can show me how to add a new layer and label it automatically. For example, create a new layer and name it layer01. Then run the script again and it will create a new layer and label it layer02 and so on.
Below is some script I found that creates a new layer but I have to name it myself. I have approx 160 layers to create and name so was hoping to do this automatically.
Can anyone help please?
Thanks
Dave
import Rhino
import scriptcontext
import System.Guid, System.Drawing.Color
def AddLayer():
    # Cook up an unused layer name
    unused_name = scriptcontext.doc.Layers.GetUnusedLayerName(False)
    # Prompt the user to enter a layer name
    gs = Rhino.Input.Custom.GetString()
    gs.SetCommandPrompt("Name of layer to add")
    gs.SetDefaultString(unused_name)
    gs.AcceptNothing(True)
    gs.Get()
    if gs.CommandResult()!=Rhino.Commands.Result.Success:
        return gs.CommandResult()
    # Was a layer named entered?
    layer_name = gs.StringResult().Trim()
    if not layer_name:
        print "Layer name cannot be blank."
        return Rhino.Commands.Result.Cancel
    # Is the layer name valid?
    if not Rhino.DocObjects.Layer.IsValidName(layer_name):
        print layer_name, "is not a valid layer name."
    # Does a layer with the same name already exist?
    layer_index = scriptcontext.doc.Layers.Find(layer_name, True)
    if layer_index>=0:
        print "A layer with the name", layer_name, "already exists."
    # Add a new layer to the document
    layer_index = scriptcontext.doc.Layers.Add(layer_name, System.Drawing.Color.Black)
    if layer_index<0:
        print "Unable to add", layer_name, "layer."
        return Rhino.Commands.Result.Failure
    return Rhino.Commands.Result.Success
if __name__=="__main__":
    AddLayer()
FYI I edited your post to enclose your code in triple backticks:
That way you get properly formatted code on our Discourse forum.
Hi @David_Gibbins,
Not exactly sure what you are looking for. Maybe this help?
import Rhino
import scriptcontext as sc
def test_add_layers():
    color = Rhino.ApplicationSettings.AppearanceSettings.DefaultLayerColor
    for i in range(0, 160):
        name = sc.doc.Layers.GetUnusedLayerName()
        sc.doc.Layers.Add(name, color)
if __name__ == '__main__':
    test_add_layers()
– Dale
Hi Dale,
Thanks for replying back so quickly.
That’s exactly what I’m after (almost). Instead of the new layers being named ‘Layer 1’, ‘Layer 2’ etc, how can I change the name to ‘Extract 1’, ‘Extract 2’ etc. and also to change the layer to colour it red?
Apologies, I should have put this in my original query but didn’t want to overload the question too early and I thought I could figure it out. I’m quite new to Python scripting and still learning.
Thanks again for your help.
Here you go:
import System
import Rhino
def _get_unused_name(prefix):
    number = 1
    while True:
        number_str = str(number)
        name = "{0} {1}".format(prefix, number_str.zfill(2))
        layer = sc.doc.Layers.FindName(name)
        if layer:
            number += 1
        else:
            return name
def test():
    color = System.Drawing.Color.Red
        name = _get_unused_name("Extract")
    test()
– Dale
That’s great. It works a treat. Thanks so much Dale.
Dave
Hello Dale,
Great work! Would it be possible to use the new layer as the current layer so the object being created is added to the new layer?
Hi @Exo,
Here you go:
import System
import Rhino
    number = 1
    while True:
        if layer:
            number += 1
        else:
            return name
def test():
    name = _get_unused_name("Layer")
    index = sc.doc.Layers.Add(name, color)
    if index >= 0:
        sc.doc.Layers.SetCurrentLayerIndex(index, False)
    test()
– Dale
Awesome! Thanks Dale
