Hi Guys,
I am having big troubles to create a surface out of this 5 crvs. I would usually loft them, but this time it doesn’t seem to work. It creates a weird srf
Yes, I know that some of the crvs are quite complex (lot of control points) but I can’t rebuild them, since I need them to be exactly in the shape and form they are. Moreover, I daily work on Rhino since years and never ever had an issue of building a srf out of TweensCrvs.
Any suggestions, please? is there (maybe) a way I am not aware of to create a srf our of closed curves?
Thanks!
Flavio
Loft Fails.3dm (108.2 KB)
Checking Refit in the Loft dialog with something like your file tolerance seems to help a lot… with the shape anyway, but it still creates a very noisy surface with a zillion control points.
Your object is also very large for millimeters and a file tolerance of .001. I might work in cm or even m with that size of an object - you can’t hold a one micron tolerance over 67 meters…
If you were to work in meters and accept a tolerance of 1 cm (0.010) - you could try the following:
Use _RebuildCrvNonUniform with a value of 0.01 (meters), it can be done within that tolerance with 121 curve points on each. Then Loft. You will get a (somewhat) nicer surface…
RebuiltLoft.3dm (243.7 KB)
Yeeeah…I know. Unfortunately this file wasn’t born very well, for a number of reasons, and I had to work on what I had received.
Anyways, thank you very much for your help
At the end, I’ve worked exactly on that direction.
