Bridge/loft Srf
would be very helpful to have Loft command work w Srf
to make simple operations like this quick & straight forward.
(currently, Crv extraction and Loft consumes quite a bit of time, esp w multiple operations)
for those quick tasks you can extrude the surface with the gumball
Hello - DupFaceBorder might be helpful.
thnx @DiegoKrause
I think with non planar srf’s, trimming is required
@pascal, can you elaborate on steps after the faces are duplicated , thnx!
the faces are not duplicated, only its borders as closed curve output. so you can use loft or extrude or whatever.
oh rgt! this def helps !
here’s 1 gd example of the tool:
https://learn.foundry.com/modo/901/content/help/pages/modeling/duplicate_geometry/bridge.html
