Create a hand-made ceramic effect?
Hi everybody,
I’d like to create a “hand-made” effect on my mug like on the photos below:
Capture d’écran 2024-02-05 à 3.35.54 PM
How would you do it? I was thinking of using _CAGE EDIT and then manually extending the points but it’s time consuming and a bit hazardous.
Any ideas?
Many thanks :slight_smile:
use a displacement texture, then exract the rendermesh if you need the geometry to be printed
Indeed that’s a good solution! Thank you Encephalon !
Hello
Noise texture seems a good candidate. It is in Rhino.
Grasshopper can also be useful. Here an example with Nautilus plugin. Not mandatory as there are other noise plugin, or tool to bump/displace vertex
Exagerated
Less exagerated
bump Mug.gh (4.5 MB)
Indeed that’s also another solution! Thanks a lot @laurent_delrieu
