Create a curviligne texte
Hello
I’m looking for write a curciligne texte around a curve. Is ist possible with Rhino?
thank you for your help
Mathieu
Create the text (TextObject, not Text) you want along a straight line in the form of curves, surfaces or solids. Then use Flow to flow the text objects from the line to your target curve. Using the Rigid=Yes option will distribute the letters along the curve without distorting them. Use Stretch=Yes to remap the length of the line to the curve if they are different.
HTH, --Mitch
Thank you very much a little bit late. That work perfect. I still have a lot to learn with rhino
Best regards
Mathieu
Télécharger Outlook pour Androidhttps://aka.ms/ghei36
