Crashing Rhino while printing layout to pdf through acrobat pdf printer
I am having this problem, persisting.
I was using Adobe pdf which now is not even shown an option in my printer list since the last update. If I use the option that just says PDF, the print takes forever, and often crashes Rhino.
I desperately need to print my drawings, so help on this asap would be great
That might be the first report of that. Are you sending in crash reports through the dialog that comes up when Rhino crashes?
A developer will first have to be able to recreate the issue. Any file that you can provide along with your system information is your first step to being helped.
Please send me the model where this happens if at all possible, We are trying to use a single default PDF exporter that we wrote for V6 which includes a lot of quality improvements over other PDF printers. I can’t fix this bug if I don’t have a sample to repeat the bug.
This is hidden by default. If you really need access to the Adobe PDF printers, go to the advanced section in options and change the setting for Rhino.Options.Appearance.ShowExternalPdfPrinters to True
RH-42956 should now be fixed in the latest BETA. Please test it out.
I had quite the same thing yet it was no issue with exactly converting the layout to pdf but when it was automatically opening in Acrobat - that’s was where the weird things were starting. For some reason the match of two of those was killing all of my documents: they were refusing to open in Acrobat and then they weren’t opening with any else piece of soft. I tried to resolve so with the web-based simple editing tool here https://ds11.pdffiller.com and it worked out for some reason, all I needed to do was just to open and save as a new pdf
