I noticed that when I run Rhino in Revit and I model there, my CPU temperature is actually far cooler versus if I run it the usual way. The average temperature I get when in Revit is around 50-65 degrees constant. But when I run Rhino in desktop it consistently goes to 75-80, which is undesirable. What’s happening here? Is there windows update I missed?
CPU temperatures depend on utilization of the CPU.
Are you doing different work using Rhino in Revit vs Rhino by itself? That would explain differences in temperature.
CPU temperatures of 75-80 C are not unexpected when the CPU is close to being fully utilized. On my desktop system with a good cooler and open case temperatures of 90 C are not unknown when CPU utilization approaches 100%.
That’s the thing, I tested it doing the same task. When I do the same 3d modeling in Revit, its 50-65 consistently. When I do the same thing in Rhino from desktop, it’s 75-80. Not only this, when I use just plain Revit , without Rhino inside Revit, it still shows me a cooler CPU temperature versus running Rhino desktop.
Mine is the opposite, if I leave going it runs much hotter. I can have 5-6 Rhino instances going with no heat, 2-3 Revits and fans don’t stop (depending on the models)
It looks like the system does not have a separate graphics system so all shading and rendering is done using the CPU. That means differences in what is displayed will affect how much work the CPU does. That directly affects the CPU temperatures?
Is there a difference in the display between working in Rhino and working in Rhino in Revit?
What display mode(s) are you using when working in Rhino? Try setting the display mode to wireframe and see if the temperatures change?
Added: Do you have a separate graphics system / GPU but it is disabled, perhaps by the power setting in Windows 10?
My gpu is not disabled, I could play games on my laptop without issue. That’s what I’m trying to ask is if maybe I have a computer setting that’s causing this. Although, I don’t think it’s a power setting thing because if I just run solely Revit or Autocad, it’s cool. But when I run solely Rhino, it’s hot. Unless I run Rhino inside revit, it’s cooler.
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 5-28-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\Acer_Nitro7\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Users\Acer_Nitro7\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Acer_Nitro7\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
There are a lot of variables here so it is difficult to tell why the GPU run hotter with Rhino by itself. Most of the time when the CPU is running hooter there is a tighter calculation loop running on the CPU. So with both Rhino and Revit running in the same process, the application essientially becomes more multip-threaded. So the CPU would need to switch tasks more often and this could potentially allow to CPU to run cooler as not all the threads have the same computational intensity.
A good example of this is rendering. Many rendering threads use the CPU and not the GPU. Raytracing for instance can be a very tight and efficient loop on the CPU and can really heat things up. If the rendering is only on one thread, then switching to other less efficient threads would allow the CPU to cool down a little as the average utilization would drop. It is possible the when Revit is not the host application, Rhino can run the CPU harder.
Now having said that, a temperature of 76 degrees is not that bad. I would only worry if the chips get up to 100 C. It is at that point that longevity would be a problem. There are some power settings if there was an overheating problem. You can drop Maximum Processor Power to 98% or 97%:
Thanks for the elucidation. I’m gonna try and tweak the battery consumption settings. As for stability, everything seems fine. It just struck me as a little weird that running Rhino by itself goes up to 70-80 degrees Celsius without really rendering much. I was concerned if maybe it’s a problem with my computer. Just curious, when you run rhino are you getting up those temperatures as well? It would be nice, I think, if Rhino could be cooler just like in RIR because I do most of my work on my laptop, and mechanically it’s better for lower temperatures so that my cooling fans won’t get too stressed and therefore have a longer lifespan. In any case i’ll take more steps to cool my laptop.
