Couple mesh between FEM (hexahedral) + Voronoi
I want to create a couple mesh system between FEM (hexahedral) with Voronoi mesh, as like image. Could you please have any idea how to create such mesh system. The projection from Voronoi Delaunay surface to FEM mesh is enough for make connection between these two types mesh.
Hello @AtikSarraz , if you want to turn Voronoi cells into a hexahedral mesh, then the easiest way to go is probably meshing each cell separately, rather than stepping outside of the cell and trying to match hex elements around them.
Of course, when you mesh each cell separately into hex elements, it’s difficult to make these match up across faces from one cell to a neighbor, but that might still be the most conceptual route. Re-use as much of the Voronoi geometry as possible.
Hi @Mathias Thanks for your kind reply.
I understood your points. Lets see if we find any other way or not.
Thanks again.
