Couldn't find the node where point load xxx is attached
Hi guys,
I was given a grasshopper script to generate the stress lines to analyse the load.
I added the surface I created to the Brep of the surface and a vertical line as the load line.
However, at the end, in the assemble model, it shows the error of " 1. Solution exception:Could not find node at (0/467.87669983449/495) where point-load number 0 is attached."
Could anyone please give me some advise what does it mean?
Thank You so much!!!
1.3dm (170.5 KB)
2.gh (63.1 KB)
2_mt.gh (62.4 KB)
Hi your meshes are not “connected” in that they do not share the same mesh vertices. You point load does not lie on the mesh itself. Please take a look at our tutorial videos on shells.
