"Could Not Find Block" error in Elefront/GH
Hi Guys!
Running in to an error when trying to reference/place blocks in Elefont. Get the error “Could not find x block” even though the blocks are definitely there (as seen by “list blocks” component. Has anyone run accross this and know how to fix it?
Thanks :slight_smile:
Rhino_wcJcMn6sYq
This may sound IT’ish, but have you tried turning it off and on again?
Seriously tho, I ran into the same issue, and it was fixed by saving anything that had to do with the file (I had linked blocks referenced), closing and reopening again :laughing:
Hope it helps!
I tried that and also importing them into a new project, importing into a project I’m working on etc. Sometimes some of them work and sometimes only 1 will work and the rest won’t. Honestly don’t know how to resolve it, doesn’t matter if I use the “list blocks in document” or just manually type it out in a panel.
I see, and how about this?, I’m doing the following and have found it a bit more stable:
I’m not sure you can see it that well, but here I have a base file with a matrix of all the blocks I need, then I use the “Reference by block name component” to import the blocks from said file. In order to expose the F parameter you need to zoom in until you see the “+” and then click on it
It’s a workaround and I would recommend plugin a data dam after it in case you are working with files stored on a server otherwise it can get pretty slow; If your files are hosted locally, depending on your disk speed, it won’t be a big deal I hope.
Awesome I will give it a shot next time in rhino
