Could Bongo use Keyshot as a renderer?
I’ll appreciate a quick answer :slight_smile: Thank you.
Roy.
Thanks for the answer Luc, I’m familiar with KeyShot’s plug-in but I wasn’t sure Keyshot can be used to render each frame automatically… can Bongo use any renderer that rhino uses?
Thanks again :slight_smile:
Roy.
The rendering of KeyShot happens outside Rhino and is launched with a special “Render” command. Bongo cannot be used to render an animation. Unfortunately.
So I’ve suspected… not so good… Thanks Luc.
I use Keyshot 5 but haven’t upgraded to V6 yet. V6 has scripting options, perhaps the two could be utilised in V6?
Possibly sending each frame to the queue
Keyshot 7 coming up soon (maybe march 17?) and it will support FBX import to bring in an animated scene to render: https://www.youtube.com%2Fwatch%3Fv%3DaXUrmGO1188&usg=AFQjCNHWU0qQcprkk39q-BTr3FTKfx6v6Q&sig2=G19mA1AIqrpIQvULsHnXsA
It would be good to know if/when Bongo will have FBX export.
Thx,
