Corrupt Hidden Display Mode when Printed as Vector
I’m getting this when printing as a Vector Graphic:
It prints correctly as a Raster Image though:
My Display drivers are up to date.
Va2.12.0.15100
Rhino7SR10
(7.10.21256.17001, 2021-09-13)
Hi @djhg, have you tried to change the dpi output of the pdf printer to a higher resolution?
Can you share the 3dm file so we can test that issue?
Thanks!
Thankyou. Here it is:
CorruptHiddenViewModePrinting.3dm (3.6 MB)
Hi @djhg,
I cannot reproduce the issue using Rhino 7 SR10 and VisualARQ 2.11.3 or VisualARQ 2.12. I get the same results using “Vector” or “Raster”.
Here is a screenshot (and the PDF file) that I get using the “Rhino PDF” printer:
CorruptHiddenViewModePrinting.pdf (63.1 KB)
I tried using “CutePDF” and “Microsoft to PDF”, and I also get the same results.
What PDF printer and printer settings are you using?
Thanks,
Enric
I have the issue on both pdf printers I use: Cutepdf and Rhino pdf.
Which printer settings are you using?
Please, can you try to uninstall VisualARQ 2.12 (you have a very old build) and install the latest VisualARQ 2.11.3?
Regards,
Enric
